질문게시판 > avr로 매트랩 이용하고 싶은데 도와주세요 ㅠㅠ
TODAY1,339 TOTAL2,317,116
BASIC4MCU | 질문게시판 | avr로 매트랩 이용하고 싶은데 도와주세요 ㅠㅠ
작성자 지수진 작성일2022-09-22 23:32 조회36회 댓글1건
아두이노를 avr로 번역해주시요 ㅠㅠㅠ
%% Description
% this code was run in Matlab 2012 ver.
%% Initialize
clc;
clear all;
%% Parameters
A = 2;                  % check value from arduino
waveFile = 'test.wav';  % sound file
fs = 44100;             % sampling rate
duration = 2;     % recording time
nbits = 16;             % using 16 bits
ard_1st = 'COM3';
ard_2st = 'COM5';
ard_baud_rate = 9600;
while 1
    arduino = serial(ard_1st, 'BaudRate', ard_baud_rate);
    fopen(arduino);
    A = fscanf(arduino, '%s');                    % read from 1st arduino
    fclose(arduino);
    if (A == '0')                                 % run when arduino sends 0
        fprintf('Recording...\n');
        y = wavrecord(duration*fs, fs);           % recording
        fprintf('Finished recording.\n');
%         fprintf('Press any key to save the sound data to %s...\n', waveFile); % pause and save manually
        wavwrite(y, fs, nbits, waveFile);         % save into wavefile in sampling rate fs, nbits
        fprintf('Finished writing %s\n', waveFile);
        [file, Fs] = wavread('test.wav');         % read wav (amplitude and sampling rate)
        B = size(file(:,1));
        N = B(1);
        f = -1 * (Fs/2) + (Fs/N):(Fs/N):(Fs/2);   % range of frequency
        f_p = 0:(Fs/N):(Fs/2-Fs/N);               % 1/2 of frequeny
        t = 0:1:B-1;                              % time range
        f_file = fft(file);                       % do fft
        f_file = abs(f_file);
        f_file_shift = fftshift(f_file);          % domain shift
        f_file_shift_p = zeros((N-1)/2,1);
        for i = 1:1:(N/2)
            f_file_shift_p(i,1) = f_file(i,1);
        end                                       % delete f below 0
        subplot(2,1,1)
        plot(t,file)
        subplot(2,1,2)
        plot(f_p,f_file_shift_p)
        xlim([0 1500])
        ylim([0 3000])
        a = 2;
        for j = 100:1:240                         % in 100 ~ 240Hz
            if (f_file_shift_p((N/Fs)*j,1) >= 1500)     % check if the amplitude over 1500
                a = 1;                            % estimate the garbage as plastic
            end
        end
        for j = 500:1:1200                        % in 500~1200Hz
            if (f_file_shift_p((N/Fs)*(j),1) >= 1000)   % check if the amplitude over 1500
            end
        end
        arduino2 = serial(ard_2nd, 'BaudRate', ard_baud_rate);
        fopen(arduino2);
        for k=1:1:400000000                 % wait few seconds
        end
        fprintf(arduino2,'%s\n',a);         % send to 2nd arduino
        fclose(arduino2);
    end
end
조회수 36
매트랩 코드는 PC에서 돌아가는 것 아닌가요?
요즘은 아두이노에서도 매트랩을 돌리나요?
아두이노든 AVR이든 시리얼통신만 보면 동일합니다.
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 13185
공지 사이트 이용 안내댓글[26] master 17-10-29 31664
질문 모터 선정에 관련하여 질문이 있습니다 이미지새글첨부파일 mint 22-09-24 13
질문 오류에 대한 질문입니다. 새글첨부파일 Tell 22-09-24 12
질문 스위치를 이용한 led2개의 밝기 순차적으로 조절입니다.댓글[2] 새글 Tell 22-09-24 24
질문 atmega128에서 소리감지 센서 질문드립니다.댓글[3] K유 22-09-23 30
현재글 avr로 매트랩 이용하고 싶은데 도와주세요 ㅠㅠ댓글[1] 지수진 22-09-22 37
질문 matlab 과 atmega128을 연동하고 싶습니다.댓글[4] dlcldl 22-09-22 27
질문 아두이노 리미트 스위치를 이용한 모터 제어댓글[1] 오모리 22-09-22 39
질문 atmega128코드로 변환 부탁드립니다 K유 22-09-21 40
답변 답변글 답변 : atmega128코드로 변환 부탁드립니다댓글[1] master 22-09-22 32
질문 아두이노 갑자기 기능구현 안됨댓글[1] 면지지 22-09-21 24
질문 아두이노 메가 외부전원공급댓글[1] 이미지첨부파일 sdwxkw12 22-09-19 37
질문 아두이노 ESP32-CAM 사용 관련 질문댓글[1] 으리둥절 22-09-19 50
질문 아두이노 코드 합치기댓글[3] 면지지 22-09-19 55
질문 빗방울 감지센서 코드 맞나 확인해주세요댓글[2] 메이트 22-09-18 56
질문 아두이노 메모리 줄여주세요! master 22-09-17 65
질문 아두이노 우노 외부 전원공급댓글[1] 니노링 22-09-17 59
질문 nodemcu와 esp8266 junwoo 22-09-16 76
답변 답변글 답변 : nodemcu와 esp8266댓글[1] master 22-09-16 32
질문 DC 모터다수를 ON/OFF 구동에 관한 질문입니다.댓글[5] asdjw44 22-09-15 94
질문 아케이드 버튼 아두이노 연결 회로도 도와주세용 이미지첨부파일 퍼피 22-09-15 65
답변 답변글 답변 : 아케이드 버튼 아두이노 연결 회로도 도와주세용 이미지 master 22-09-15 54
질문 5V 모터 100개를 구동댓글[1] asdjw44 22-09-15 56
질문 아두이노랑 아케이드 버튼 연결 회로도 한번만 봐주세요!댓글[1] 첨부파일 퍼피 22-09-15 42
질문 아두이노코드 합치기 문의드립니다! 첨부파일 Linie 22-09-13 73
답변 답변글 답변 : 아두이노코드 합치기 문의드립니다! master 22-09-14 64
질문 아두이노 우노로 키보드명령댓글[1] 차따뚜이 22-09-09 110
질문 attiny85 코딩 질문입니다.댓글[2] 무야더싱 22-09-08 69
질문 코딩 질문합니다. 에그젤리 22-09-07 94
