질문게시판 > atmega128 recipe for target 'main.o ' failed 오류
TODAY3,267 TOTAL3,511,985
BASIC4MCU | 질문게시판 | atmega128 recipe for target 'main.o ' failed 오류
작성자 hhhyyyeee 작성일2024-06-19 22:22 조회137회 댓글3건
ISR(INT4_vect)
if(toggle == 0)
pulse_count = 0;
TCCR0= 0x02;
TCNT0= 140;
EICRB= 0x02;
TIMSK = 0x01;
toggle = 1;
EICRB = 0x03;
TIMSK = 0x00;
TCCR0 = 0x00;
toggle = 0;
이 부분에서 recipe for target 'main.o ' failed 오류가 나는데 이유를 모르겠어요 ㅠㅠ 코드를 어떻게 수정하면 될까요?
댓글 3
조회수 137
전체 소스코드를 첨부하세요
선언하지 않은 변수가 있는지 체크해보세요
hhhyyyeee님의 댓글
hhhyyyeee 댓글의 댓글 작성일
#define F_CPU 16000000UL
#include <stdio.h>
#define LCD_DB_PORT  PORTA
#define LCD_DB_DDR  DDRA
#define LCD_CMD_PORT  PORTC
#define LCD_CMD_DDR  DDRC
#define SW_PORT PORTD
#define SW_DDR DDRD
#define SW_PIN PIND
#define US_PORT PORTE
#define US_DDR DDRE
#define BUZZER_PORT PORTF
#define BUZZER_DDR DDRF
#define DIST_MIN 4
#define DIST_MAX 50
#define HEIGHT_MIN 15
#define HEIGHT_MAX 35
#define YES 12
#define NO 34
volatile unsigned int pulse_count = 0;
volatile unsigned char togle = 0;
unsigned char UP_flag = NO;
unsigned char DOWN_flag = NO;
char str[16];
void pulse(void)
US_PORT = 0x01;
_delay_us(10);
US_PORT = 0x00;
ISR(TIMER0_OVF_vect)
pulse_count++;
TCNT0 = 140;
ISR(INT4_vect)
if(togle == 0)
pulse_count = 0;
TCCR0= 0x02;
TCNT0= 140;
EICRB= 0x02;
TIMSK = 0x01;
togle = 1;
EICRB = 0x03;
TIMSK = 0x00;
TCCR0 = 0x00;
togle = 0;
void LCD_cmd(unsigned char cmd)
LCD_CMD_PORT = 0x00;
LCD_DB_PORT = cmd;
LCD_CMD_PORT = 0x01;
_delay_us(1);
_delay_us(100);
void LCD_init(void)
LCD_cmd(0x38);
LCD_cmd(0x0C);
LCD_cmd(0x06);
LCD_cmd(0x01);
_delay_ms(2);
void LCD_data(unsigned char data)
LCD_CMD_PORT = 0x02;
LCD_DB_PORT = data;
LCD_CMD_PORT = 0x03;
_delay_us(1);
_delay_us(100);
void LCD_print(unsigned char cmd, char *str)
LCD_cmd(cmd);
while(*str != 0)
{ LCD_data(*str);
str++;
void LCD_char_print(unsigned char cmd, char *str)
LCD_cmd(cmd);
LCD_data(*str);
void Title_display(void)
LCD_print(0x80,"[PUSHUP COUNTER]");
LCD_print(0xC0," PRESS ANY KEY..");
void Buzzer_short(void)
BUZZER_PORT = 0x01;
_delay_ms(10);
BUZZER_PORT = 0x00;
void Buzzer_long(void)
BUZZER_PORT = 0x01;
_delay_ms(100);
BUZZER_PORT = 0x00;
void Counting_mode(void)
unsigned int num = 0;
sprintf(str,"      %u        ",num);
LCD_print(0x80,"    COUNTING    ");
LCD_print(0xC0,str);
pulse();
_delay_ms(60);
if(pulse_count > DIST_MIN && pulse_count < DIST_MAX)
if(UP_flag == NO && pulse_count > HEIGHT_MAX)
UP_flag = YES;
if(UP_flag == YES && pulse_count < HEIGHT_MIN)
UP_flag = NO;
DOWN_flag = YES;
if(DOWN_flag == YES && pulse_count > HEIGHT_MAX)
DOWN_flag = NO;
Buzzer_short();
sprintf(str,"      %u        ",++num);
if(SW_PIN == 0b00000000)
_delay_ms(20);
num = 0;
Buzzer_long();
void Port_Setting()
LCD_DB_DDR = 0xFF;
LCD_DB_PORT = 0x00;
LCD_CMD_DDR = 0xFF;
SW_DDR = 0xF0;
SW_PORT = 0x01;
US_DDR = 0x0F;
US_PORT = 0x00;
BUZZER_DDR = 0x0F;
BUZZER_PORT = 0x00;
Port_Setting();
LCD_init();
_delay_us(50);
EICRB = 0x03;
EIMSK = 0x10;
ACSR = 0x80;
sei();
Title_display();
_delay_ms(20);
Buzzer_long();
Counting_mode();
} 이게 전체 코드입니다! ㅠㅠ lcd_print 부분에서도 오류가 나는데 뭐가 문제인지 모르겠어요 ㅠㅠㅠ
AVRstudio4에서 오류 발생하지 않습니다.
새프로젝트 만들기로 다시 컴파일 해보세요
공지 MCU, AVR, 아두이노 등 전자공학에 관련된 질문은 질문게시판에서만 작성 가능합니다. 스태프 19-01-15 23805
공지 사이트 이용 안내댓글[31] master 17-10-29 37808
질문 아두이노 초음파센서 연결 + 컴퓨터 연결 제발 도와주세요댓글[1] 이미지새글첨부파일 pinkpong 24-07-14 19
질문 아두이노 여러 센서 연결댓글[4] 이미지첨부파일 공수백자 24-07-09 154
질문 기어드 모터 외부인터럽트 사용하여 1초 동안 펄스 세는 법댓글[3] 바밤 24-07-04 124
질문 STM32F429ZIT6 rtc alarm 인터럽트 i2c lcd에 구현하는 방법댓글[5] aaahhhj 24-06-29 202
질문 Atmega128 LCD 출력이 나오지 않습니다, 코드 확인 부탁드립니다. 이미지첨부파일 코드에막혀 24-06-25 55
답변 답변글 답변 : Atmega128 LCD 출력이 나오지 않습니다, 코드 확인 부탁드립니다.댓글[1] master 24-06-25 58
현재글 atmega128 recipe for target 'main.o ' failed 오류댓글[3] hhhyyyeee 24-06-19 138
질문 atmega128 코드 합치기 앗메 24-06-18 94
답변 답변글 답변 : atmega128 코드 합치기 master 24-06-19 47
질문 아두이노 파력발전댓글[1] sighn 24-06-16 79
질문 ATmega4809 nRF24L01 모듈을 이용한 무선 통신댓글[3] Ahri 24-06-12 145
질문 atmega128에 dht11 왜 측정을 못하죠?댓글[1] 탈북한시민 24-06-11 101
질문 atmega128이 실행이 되지 않습니다댓글[1] 이미지첨부파일 니굴 24-06-10 79
질문 아트메가 128 쓰는디 while 문이 안먹혀요댓글[1] 수히 24-06-09 81
질문 atmega128 UART통신으로 FND출력 Rion 24-06-09 110
답변 답변글 답변 : atmega128 UART통신으로 FND출력댓글[1] master 24-06-10 107
질문 atmega128 라인트레이서 코드와 회로도 질문...몇일 째 머리아파 죽겠네요ㅠ댓글[2] 이미지첨부파일 왕두일 24-06-06 244
답변 답변글 답변 : atmega128 라인트레이서 코드와 회로도 질문...몇일 째 머리아파 죽겠네요ㅠ master 24-06-07 133
질문 atmega128을 이용한 LCD 사용에 문제가 발생했습니다.댓글[3] 이미지 네넴 24-06-05 786
질문 Co 센서 값에 따른 ppm을 계산하려는데댓글[1] 라칸 24-06-05 150
질문 17HS4401, A4988 스텝모터 제어댓글[1] 이미지 jhbaik 24-06-03 180
질문 코드비전avr을 이용한 아두이노 우노 제어댓글[1] gkstntjd 24-05-29 194
질문 Energia 시리얼 모니터에 아무것도 출력되지않습니다.댓글[1] 김의공 24-05-22 203
질문 아두이노 스위치, 에어펌프 연결댓글[1] 이미지첨부파일 존존 24-05-20 370
질문 MSP430런치패드를 이용한 LCD 코딩 관련 질문댓글[1] 뀨쥰이 24-05-16 248
질문 생활 속 가스 센서 이미지첨부파일 Fosen 24-05-13 121
질문 atmega128A로 초음파센서 바밤 24-05-13 288
답변 답변글 답변 : atmega128A로 초음파센서 master 24-05-13 251
