BASIC4MCU | 질문게시판 | stm32 절전모드에 대해서
작성자 라칸 작성일2024-08-29 18:56 조회1,587회 댓글2건본문
https://blog.naver.com/eziya76/221543393453
위 블로그을 참고로해서 Sleep모드와 Stop모드 전환하고 일정시간 뒤에 다시 TASK가 동작하게 만들고 있는데task에서 Stop나 Sleep모드 메소드를 실행해도
for문 첫부분의 vTaskDelay로 넘어가더니 그대로 동작이 제대로 안하는데
일정시간 지나기 전에 절전상태 전환은 되어서 실행하는건데RTC 부분 문제인가요?
void RTC_Init(void)
__HAL_RCC_RTC_ENABLE();
hrtc.Instance = RTC;
hrtc.Init.HourFormat = RTC_HOURFORMAT_24;
hrtc.Init.AsynchPrediv = 127;
hrtc.Init.SynchPrediv = 255;
hrtc.Init.OutPut = RTC_OUTPUT_DISABLE;
hrtc.Init.OutPutPolarity = RTC_OUTPUT_POLARITY_HIGH;
HAL_RTC_Init(&hrtc);
// Get current time
RTC_TimeTypeDef currentTime;
HAL_RTC_GetTime(&hrtc, ¤tTime, RTC_FORMAT_BIN);
// Calculate alarm time (current time + 30 seconds)
RTC_AlarmTypeDef sAlarm;
sAlarm.Alarm = RTC_ALARM_A;
sAlarm.AlarmTime = currentTime;
sAlarm.AlarmTime.Seconds += 30;
// Handle overflow of seconds
if (sAlarm.AlarmTime.Seconds >= 60)
sAlarm.AlarmTime.Seconds -= 60;
sAlarm.AlarmTime.Minutes++;
if (sAlarm.AlarmTime.Minutes >= 60)
sAlarm.AlarmTime.Minutes -= 60;
sAlarm.AlarmTime.Hours++;
if (sAlarm.AlarmTime.Hours >= 24)
sAlarm.AlarmTime.Hours -= 24;
sAlarm.AlarmSubSecondMask = RTC_ALARMSUBSECONDMASK_NONE;
sAlarm.AlarmMask = RTC_ALARMMASK_DATEWEEKDAY;
sAlarm.AlarmDateWeekDaySel = RTC_ALARMDATEWEEKDAYSEL_DATE;
sAlarm.AlarmDateWeekDay = 0;
HAL_RTC_SetAlarm_IT(&hrtc, &sAlarm, RTC_FORMAT_BIN);
void HAL_RTC_AlarmAEventCallback(RTC_HandleTypeDef *hrtc)
// Handle the alarm event
// This function will be called when the 50 seconds elapse
// Exit the Sleep/Stop mode or perform other necessary actions
void SleepMode(void)
HAL_GPIO_TogglePin(GPIOB, GPIO_PIN_14);
/* Suspend SysTick */
HAL_SuspendTick();
/* Enable Power Peripheral */
__HAL_RCC_PWR_CLK_ENABLE();
/* Initialize RTC */
RTC_Init();
/* Sleep Mode */
HAL_PWR_EnterSLEEPMode(PWR_LOWPOWERREGULATOR_ON, PWR_SLEEPENTRY_WFI);
/* Resume SysTick When System Wake-up */
HAL_ResumeTick();
void StopMode(void)
HAL_SuspendTick();
RTC_Init();
/* STOP Mode */
HAL_PWR_EnterSTOPMode(PWR_LOWPOWERREGULATOR_ON, PWR_SLEEPENTRY_WFI);
HAL_ResumeTick();
/* PLL Clock Recovery */
SystemClock_Config();
void HAL_GPIO_EXTI_Callback(uint16_t GPIO_Pin)
static uint32_t debounce = 0;
static uint32_t now = 0;
if(GPIO_Pin == GPIO_PIN_0)
/* anti-chattering */
now = HAL_GetTick();
if(now - debounce < 200) return;
debounce = HAL_GetTick();
/* USER CODE END 4 */
/* USER CODE BEGIN Header_mainTask */
* @brief Function implementing the MainTask thread.
* @param argument: Not used
* @retval None
/* USER CODE END Header_mainTask */
void mainTask(void const * argument)
/* init code for USB_HOST */
MX_USB_HOST_Init();
/* USER CODE BEGIN 5 */
/* Infinite loop */
for(;;)
vTaskDelay(pdMS_TO_TICKS(10000)); // 1초 동안 Delay
if (osSemaphoreWait(SPHandle, osWaitForever) == osOK)
MX_USB_HOST_Process();
if(Appli_state == APPLICATION_READY)
HAL_GPIO_WritePin(GPIOB, GPIO_PIN_7, GPIO_PIN_RESET);
vLogFile(&FullData);
HAL_GPIO_WritePin(GPIOB, GPIO_PIN_7, GPIO_PIN_SET);
/* 세마포어 해제 */
osSemaphoreRelease(SPHandle);
SleepMode();
/* USER CODE END 5 */
댓글 2
조회수 1,587master님의 댓글
저는 RTOS를 좋아하지 않아서 공부하지 않았습니다.
초보자 때에는 대단한 것을 제공하는 것 같아서 RTOS를 좋아하지만
복잡한 제어를 하게 될 수록 RTOS를 상세히 모르면 문제 발생 시 대처가 어렵기 때문이죠
디버깅 방법은
디버거를 통해서 코드 실행을 추적하는 방법도 있고
시리얼모니터에 어느 부분을 실행 중인지 메시지를 출력하는 방법도 있습니다.
